Discussion topic: Issues with Sky
Message posted on 17 Dec 2023 04:20 PM
Issues with Sky
Hi there
my satellite signal has gone and has been for the few days . Won't load to guide and the channels are scrambled
Message posted on 17 Dec 2023 04:38 PM
Re: Issues with Sky
@Mark610861
”No signal” tends to be a message from your TV (in which case check the cables going to the TV). A “no satellite signal” message relates to your Sky box.
If a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. After that look at the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish (it’s not something that will necessarily be visible to the naked eye). If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
