Discussion topic: Issues recording on Sky Q box!
Message posted on 06 Jul 2024 10:40 AM
I have been having issues recording certain channels on my Sky Q box for a few months now. It started missing recordings on Sky Witness initially with a variety of error messages such as no signal, broadcaster issue or subscription required and now won'a record this channel at all. Sky Atlantic is also missing programmes here and there but this is getting more frequent and this week, it stopped recording ITV 2. I have tried the hidden menu and doing the 'soft' reset but no luck. I have HD and all the channels I'm trying to record in my packeage. I can download the programmes if they don't record but it's frustrating to be paying for services I am unable to access. Any help would be most appreciated. Thanks in advance. I contacted Sky but they suggested I do a hard reset, lose all my current recordings and if that didnt work, get a new box!! Felt like a hard no from me as I have things saved on there that I can't get again.
Message posted on 06 Jul 2024 11:04 AM
Re: Issues recording on Sky Q box!
Hi @MelHol
If you have already carried out a reset settings in the hidden menu then it looks like a Factory reset is you only option.
However you could check that your Disc space is not getting low.
Also you could try noting all your scheduled recordings and series links.
Then go through the scheduled section and remove all series links from the right hand side. Make sure you leave the recording scheduled at this stage (only remove any series links).
Once you have removed all the series links remove all scheduled recordings until the scheduled section is completely empty.
Then reboot your Q
When the box is completely back up and fully running add back your Recordings and series links.
Message posted on 06 Jul 2024 02:22 PM
Thank you for the suggestion. Once I do all of that and reboot, do I then just put all of the scheduled recordings back on the box??
Message posted on 06 Jul 2024 03:19 PM
