Discussion topic: Issue with sky q box
This message was authored by: Tubby+T
Constantly download failed on every channel?
Re: Issue with sky q box
Hi @Tubby+T
First try rebooting your Broadband router .
Disconnect power lead for 30 sec and then reconnect to reboot.
Wait until the router is back up and fully running and then
