Discussion topic: Is apple tv+ on sky q actually 4k hdr?
Message posted on 31 Mar 2023 06:59 PM
Nice simple question, hopefully a simple answer!
Assuming I have the right tv to display UHD HDR content, does the sky q version of the apple tv+ app display in UHD HDR or would the picture from a dedicated streaming box be better?
Message posted on 31 Mar 2023 07:12 PM
Re: Is apple tv+ on sky q actually 4k hdr?
@PAYNE.DAVID wrote:Nice simple question, hopefully a simple answer!
@PAYNE.DAVID no reason why it shouldn't unless you have the non HDR Sky Q box.
Have you tried watching any UHD/HDR content via the Appletv+ app to see if the HDR popup appears.
If you are still doubting I can provide screenshots if you give me the title of the programme or film
Message posted on 06 Nov 2023 09:25 AM
My issue is apple tv+ picture quality on sky q box. I've just enabled the apple TV+ this week. I'm currently watching the series invasion and the picture quality is probably less than SD. My sky q box is hard wired, and my speed is 70mbs. I've looked everywhere to change the settings ( if it can be done) and the only one is I can see is to turn on sd only for slow internet on the apple settings. My TV is a Sony bravo and the video settings is 1080 and my sky q box is also set to 1080. I've also searched the internet for answers but can't find anything.
Message posted on 06 Nov 2023 10:25 AM - last edited: 06 Nov 2023 10:28 AM
1080 is sdr, not hdr. For hdr the sky box should be set to 2160p https://www.sky.com/help/articles/setting-up-ultra-hd
According to here apple tv is uhd or hdr https://www.sky.com/help/articles/watching-sky-q-in-ultra-hd
All appletv content was actually converted to HDR10+ last year.
However I prefer to use my own tv's apps as they can result in better PQ.
Message posted on 06 Nov 2023 02:09 PM
My TV is 1080, if I set the q box to 2160 it says not available.
Message posted on 06 Nov 2023 08:20 PM
@Phillipjames Why are you trying to watch 4k UHD on Apple Tv+ if you only have a HD TV or am I missing something 🤔
Your TV will only display upto 1080 that's why 2160 isn't available.
Sky Q 2Tb HDR
Mini Box
Sky Full Fibre 300
Message posted on 07 Nov 2023 08:28 AM
Yes my TV will only display 1080. But apple TV+ is only displaying SD at 480, if it was 720 (hd) it wouldn't be too bad. And yes my settings say no to SD.
Message posted on 07 Nov 2023 09:53 AM
@Sparkymatt100 wrote:@Phillipjames Why are you trying to watch 4k UHD on Apple Tv+ if you only have a HD TV or am I missing something 🤔
He's not trying to watch UHD. The OP was a different person.
Message posted on 07 Nov 2023 09:54 AM
@Phillipjames wrote:Yes my TV will only display 1080. But apple TV+ is only displaying SD at 480, if it was 720 (hd) it wouldn't be too bad. And yes my settings say no to SD.
Does the ATV+ app show you the bitrate it's able to stream at? Like netflix does?
Message posted on 07 Nov 2023 11:40 AM
I'm afraid not, there's very little you can play with in settings.
