Discussion topic: Internet not connecting
Message posted on 03 Dec 2023 10:28 AM
The internet is not connecting to my sky q box however it is working properly on other devices. There is no error code showing. I have followed other description's steps to fix the problem but no luck
Message posted on 03 Dec 2023 10:35 AM
Re: Internet not connecting
Hi @Blabla1
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
