Discussion topic: Internet connectivity error
Message posted on 02 Mar 2024 08:06 PM
My sky box is connected to the wrong WiFi network so cannot get internet. How can I change the network and select the correct one?
Message posted on 02 Mar 2024 08:28 PM
Re: Internet connectivity error
Hi @Alexau01
If on Sky broadband first reset your broadband router by holding Reset on the back until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
Message posted on 02 Mar 2024 09:10 PM
Thank you very much for your help. I'm not in sky broadband and have connected the main sky Q box correctly, now the mini box is unable to find it. I've restarted and reset the skyQ box and have tried to reset the mini boxv several times. It's very frustrating!
Message posted on 02 Mar 2024 09:15 PM
Hi @Alexau01
Reboot the mini as above.
Message posted on 02 Mar 2024 09:46 PM
Thanks very much indeed, it suddenly came to life by itself!
