4
This discussion topic has been answered Discussion topic: Internet connection
This message was authored by: Janikk
Internet connection
No internet conection on tv but have on mobile phone
Re: Internet connection
@Janikk wrote:
Platform ?
I have a sky Q box if that's any help
Hi @Janikk
@Janikk  Which platform is your TV running from Sky?
Avatar for Janikk
Platform ?
@Janikk wrote:
Platform ?
Hi @Janikk
Avatar for Janikk
Thank you. Worked
