Discussion topic: Intermittent recording failure
This message was authored by: SD2TB
When I set up a series link to record ,
It sometimes misses episodes, it's pretty random,.
 I have previously spoke to a technician on the phone, he suggested deleting as much as possible from my Q box,
I did this, nothing has changed!
also the box turns itself on, and then also turns my TV on! This could happen any time of day even after I have gone to bed!
Re: Intermittent recording failure
Hi @SD2TB
Avatar for SD2TB
Thanks for all that,
 I have tried that and nothing changed
the guy on the phone from sky said it would probably be a new box required after a engineer visit!
 I get fed up of ringing them!
thanks again!
