Discussion topic: Intermittent pixelating problems
This message was authored by: Lloyd27
My sky q starts to pixelate then gets worse till it comes up with no satellite signal being received. A couple of days later it is fine. I have cancelled an engineer twice because of this. The weather has no bearing on the problem.
Re: Intermittent pixelating problems
Probably still needs an engineer to check the dish alignment,  (And or LNB/cabling)
Or treeline
or how securely the dish is attached
