Discussion topic: Inputting correct password for sky Q box
This message was authored by: Brian19671
I input the wrong WiFi password on my skyQ box and I can't get back to change
Re: Inputting correct password for sky Q box
Reset network in the settings
This message was authored by: kyla598ellis
Hello @Brian19671,
Go to Settings > Setup > Network > Reset on your Sky Q box. This will clear the current WiFi settings and let you re-enter the correct password. If the menu is unresponsive, restart the box and try again.
Best Regards,
Kyla Ellis
Avatar for Brian19671
Thanks for responses and got it sorted
 Brian
