Discussion topic: Input source problem after connecting sky Q remote remote to tv
Message posted on 17 Oct 2023 12:44 AM
Hi ive connected my sky Q remote to my Bush tv and the power and volume buttons work fine but I cannot change the input source with the button on the remote.... Any help would be appreciated
Message posted on 01 Jan 2024 12:17 PM
Re: Input source problem after connecting sky Q remote remote to tv
I'm having the same issue with my Panasonic tv - I press source the options come up but I cannot select another input. Did you manage to fix the issue?
Message posted on 01 Jan 2024 12:42 PM - last edited: 01 Jan 2024 12:42 PM
@Katie73 wrote:I'm having the same issue with my Panasonic tv - I press source the options come up but I cannot select another input. Did you manage to fix the issue?
Why not use your TV remote to change the input source?
Message posted on 01 Jan 2024 01:43 PM
Hi @Katie73 keep pressing the source button on the Sky Q remote until the correct source is highlighted for example HDMI 2 Apple Tv after a few seconds it will select it automatically for you then it should change to HDMI 2 with pressing anything else.
Message posted on 01 Jan 2024 02:22 PM - last edited: 01 Jan 2024 02:22 PM
Yeah the sky remote can only cycle through inputs. It can't control/simulate the arrow keys/OK button of the original TV remote to navigate menus.
