Discussion topic: Incorrect password?!
Message posted on 08 Nov 2023 05:13 PM
Good evening everyone!
I haven't been able to access my apps on sky q as it says my wifi password is incorrect - when it is not. Can someone help please?
Message posted on 08 Nov 2023 05:24 PM
Re: Incorrect password?!
Hi @Nai
If you are trying to sign in to Apps on your Q box it is not your WiFi password which is required.
Certain Apps need activating and are set up using a password that you need to set up during Activation.
If you cannot use your Apps because your Q box has no internet connection then try a Network reset exactly as follows.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
