4
This discussion topic has been answered Discussion topic: ITVX
This message was authored by: BT57
ITVX
What do I have to do to get ITVX on my Sky Q
i thought it was now available on SkyQ but it's not in my apps, I've rebooted etc
Avatar for BT57
This message was authored by: BT57 Answer
Re: ITVX
Software update has sorted it eventually, thanks for your help
Re: ITVX
Hi @BT57   The voice command I T V X sometimes kicks it into place. Are you on the latest software Q210?
Avatar for BT57
Re: ITVX
Tried the voice command with no luck but I'll check the software see if it's updated
thank you for reply
Avatar for BT57
Re: ITVX
Avatar for BT57
Re: ITVX
