Discussion topic: ITV1 channel constantly breaking up
This message was authored by: JillyHud1
ITV1 is constantly pixilating. it can last anywhere from twenty minutes to several hours. It also happens on several Sky Channels - All other channels are fine, I haveno problem with them, I have a Sky Q box. I have tried switching it on. and off - doesn't work. I even followed the instruction on the chatbox on here.. Didn't work. Has anyone else had/having this problem?
Re: ITV1 channel constantly breaking up
@JillyHud1 sound like your dish may have moved slightly you will need to contact Sky to arrange an engineer to come out and chech the alignment of your dish
You can contact Sky by phone by dialling 150 if Sky is your phone provider or by following the link below
https://www.sky.com/help/home
scroll down to need more help click on this and you will find a phone number. If you are in ROI please change the flag at the bottom right to the ROI flag
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: Paulgoode
Same happens on my sky stream. Always ITV 1
