Discussion topic: ITV1 HD on Sky Q Missing
Message posted on 08 Jan 2024 05:49 PM
Message posted on 08 Jan 2024 06:13 PM
Re: ITV1 HD on Sky Q Missing
@lesbutcher wrote:
Got a replacement box, there is no ITV1 HD anywhere?
@lesbutcher so what channel is showing at 103 ?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 08 Jan 2024 06:17 PM
Message posted on 08 Jan 2024 06:19 PM
@lesbutcher wrote:
Hi, it's just ITV, so SD not HD, the other HD channels are on Channel 801, 802 and 803 apart from BBC 1 HD which is still 101
@lesbutcher you might find ITV1HD on 803 then it should be on 103 so try giving your box a reboot
ie
Message posted on 08 Jan 2024 06:25 PM
Message posted on 08 Jan 2024 06:26 PM
@lesbutcher wrote:
Yes I've already tried rebooting , it's not there at all.
@lesbutcher so whats on 803 then ?
Message posted on 08 Jan 2024 06:41 PM
Message posted on 08 Jan 2024 07:21 PM
@lesbutcher Have you put your viewing card into the new box?
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 08 Jan 2024 07:26 PM
Message posted on 08 Jan 2024 07:29 PM
@lesbutcher To be honest, I'm surprised anything works without a viewing card. Your viewing card is basically your subscription.
Message posted on 08 Jan 2024 07:30 PM - last edited: 08 Jan 2024 07:31 PM
That explains it, without a viewing card you'll just get the default channels, for ITV I think the default is ITV1 Central West SD.
Message posted on 08 Jan 2024 07:42 PM
Message posted on 08 Jan 2024 08:35 PM
If it was a replacement box, assume you accidentally left your card in your old box that was carted off?
