Discussion topic: ITV + 1 Chanels
Message posted on 25 Jan 2025 06:57 PM
ITV + 1 Chanels
I have a no signal message on the ITV + 1 Chanels all other Chanels ok
Message posted on 25 Jan 2025 07:00 PM
Re: ITV + 1 Chanels
@Anne+Tyrer
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment so check the troubleshooting on this link
It’s worth noting that:
1 - a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels and
2 - a Sky Q box requires a periodic 'Keep alive' signal that is delivered via the satellite so if that isn’t received the box will close down until the satellite signal is restored.
