Discussion topic: I neef
This message was authored by: SamBrady
Message posted on 08 Oct 2023 02:55 PM
I neef
I need an engineer to move the cables
Find out more
Message posted on 08 Oct 2023 03:05 PM
Re: I neef
Which cables? If external Sky charge about £65 for this.
Find out more
Message posted on 08 Oct 2023 03:06 PM
Re: I neef
@SamBrady @You can book an engineer visit here: https://www.sky.com/help/articles/book-engineer-sky-q
If you just want to move the cables internally you can buy shotgun cable extenders from Amazon or similar.
If the move is more complicated or if Sky won't do it (they may only do repairs), then contact a local satellite installer to do the work.
