Discussion topic: I have multi room ....the main box is fine but downstairs the picture keeps freezing
This message was authored by: Pab3
My Sky box downstairs ( not main box) the picture keeps freezing
Re: I have multi room ....the main box is fine but downstairs the picture keeps freezing
Hi @Pab3
Reboot the mini as above.
