Discussion topic: I have changed my Sky Q box and there is still no internet connection
This message was authored by: Stelio1
Do you think the problem is my router? All other computers in the house are connected ok.
Re: I have changed my Sky Q box and there is still no internet connection
Hi @Stelio1
Have you completed the following procedure correctly?
