Discussion topic: I have an error on my sky mini box
Message posted on 12 Mar 2023 09:23 PM
My sky mini box isn't working I have an error MR001
Message posted on 12 Mar 2023 09:38 PM
Re: I have an error on my sky mini box
Hi @ELFREDA
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
