Discussion topic: I have a problem with my sky Q mini box
Message posted on 12 Aug 2024 03:41 PM
Rocks
i have a problem with my sky Q mini box
Message posted on 12 Aug 2024 03:46 PM
Re: I have a problem with my sky Q mini box
More details please @DavidRocks
Message posted on 12 Aug 2024 03:49 PM
@DavidRocks wrote:
Rocks
Hi @DavidRocks
Reboot the mini as above.
