Discussion topic: I cannot connect my skyq boxes to broadband
This message was authored by: Andrew+Pull
Having been told to reset the router I cannot now connect any skyq boxes to sky
Re: I cannot connect my skyq boxes to broadband
Hi @Andrew+Pull
First connect your main Q box.
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
When you get the main Q box connected then Reboot the mini.
To reboot press Standby on your mini remote (if the box responds to the remote), and then switch off and unplug at the mains.
Wait at least 30 secs and then Plug back in and switch your mini box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your mini remote or if this is not working press the standby button on the front of the mini box (Amber led)
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
Avatar for Andrew+Pull
Many thanks - I took your advice and seem to have got the system back up and running. The key point was rebooting the main Sky box.
