Discussion topic: I am having problems with my sky box
This message was authored by: Hilda94
I am having problems with my recording also getting messages  and losing sky I  am having to turn off and rest and finally the sky box gets very hot
Avatar for Hilda94
Level 0 icon
Re: I am having problems with my sky box
Can you help me with my Q box
Hi @Hilda94
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Bear in mind you will also lose all your recordings,  although any buy and keep from Sky Store can be downloaded to a replacement Q box
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
