Discussion topic: How to order a sky viewing card
This message was authored by: Jenko2508
How to order a new viewing card
Re: How to order a sky viewing card
@Jenko2508
You would have to call Sky to order one then it's sent out in the post? Why do you need one (unless you've done a doorstep box swap and left the card in the faulty box)?
▪️I AM NOT A SKY EMPLOYEE ▪️
If your viewing card seems faulty, have a look at this Sky help article with any on screen messages you may be seeing or how to repair a faulty viewing card;
https://www.sky.com/help/articles/viewing-card
This message was authored by: Sue19581
Not getting all my sky channels
Need new card
  • No
Need new card
You need yo speak directly to Sky then.     @Sue19581
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
https://www.sky.com/help/home
This message was authored by: Highwayman-78
  • Require new  viewing card
See posts #3 and #6
This message was authored by: BBrush
Thanks for the info. The card we have is getting very burnt and the signal keep dropping and it's not the weather, I'm also getting a new lnb just in case.
Need a new vewing card
@Sue19581
You need to contact Sky. What's the reason for needing a new card?
It's not getting burnt. It's just the colorization of the glue that holds the chip in the card. Perfectly normal. A loss of satellite signal is either a dish alignment, a failing LNB or cable damage.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Thanks for that much appreciated
