Discussion topic: How to get a wifi booster
This message was authored by Iain+2 This message was authored by: Iain+2
Hi,
I have intermittent issues with wifi connection to my tv connected by a mini box. The picture freezes for a few seconds then comes back for a while and then freezes again. I have checked all the connection settings on the q box and the sky hin is approximately 5m from the mini box with nothing obstructing the signal. How do i get a wifi booster without having an engineer come out for an intermittent problem which will mean a day off work. I have broadband with guarantees speeds et. Any help would be appreciated. Many thanks,Iain
This message was authored by bob1234 This message was authored by: bob1234
Re: How to get a wifi booster
@Iain+2You will have to phone Sky, they will provide boosters free if needed, however would it be possible to use an Ethernet cable between your Q box and router which should cure the problem for good.
