Discussion topic: How many sky mini boxes can you have
This message was authored by: Victor+Morris
I would like a 3rd sky mini box to link with my sky q, can you have three connected and if so what is the cost and process for getting the third box,
Re: How many sky mini boxes can you have
hi @Victor+Morris
You can have up to 4 mini boxes on the account but can only use 2 simulataneously for Satellite TV or Recordings - although we believe you can use a 3rd at the same time  if using it for apps like Netflix or Disney + (& before using the others)
I think the one off admin fee is usually £50 (Although I may be out of date)    no additional monthly cost.
You may be able to order online or via the SKY Q box - although I have seen some reports that these may not be there  at the moment - in which case you would need to call SKY
Hi @Victor+Morris
You can have up to four minis installed on loan each subject to a one off upfront charge and all under by one single Q monthly Multiscreen subscription
However only two minis can be used simultaneously on all 2 TB boxes and the 1 TB UHD Main boxes to watch Sky Q content.
The original 1 TB non UHD box only permits the use of one mini at a time.
If Sky Apps are already being used on some of the minis these will not normally be counted as in Q use and therefore can be used in addition to the above limits.
See the following link for the Versions of main Q box referred to above.
https://www.sky.com/help/articles/sky-software-updates
Subject to the above limits Sky Q minis can be used completely independently of the main Q box and the same or different program or recording can be viewed on each Q box. Even if viewing the same content it is completely independent and can be viewed at the same or different point.
Minis can do all the features same as the main Q box and can set or delete recordings on the main Q box hard drive. There is one single storage area on the main Q box with no profiles and no indication of which Q box has set a recording. (Unlike Sky+HD Multiroom which has independent storage and planners).
It should also be remembered that minis cannot view UHD recordings or content.
