Discussion topic: How do you fix error mr106
Message posted on 07 Aug 2026 09:45 PM
Message posted on 08 Aug 2026 05:36 AM - last edited: 08 Aug 2026 05:37 AM
Re: How do you fix error mr106
@catlady1666
It’s always worth starting with a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
