Discussion topic: How do i synchronise apps on main q box with mini box
Message posted on 03 Sep 2026 07:18 PM
How can I synchronise the apps on my sky mini q box to be the same as on my main sky q box?
Message posted on 03 Sep 2026 07:25 PM
Re: How do i synchronise apps on main q box with mini box
Message posted on 03 Sep 2026 07:32 PM
Hi thanks for responding.
I would like the apps on the mini box to be the same as on the main box. I only have 2 apps on the mini and about 10 on the main box
Message posted on 03 Sep 2026 07:38 PM
hi @Webbydog
Please see this link to check/ refresh apps
Follow the steps on this link (skipping any that are OK):
https://www.sky.com/help/articles/apps-on-sky-q-and-glass-basic-checks
Please note that the step to refresh apps often does not action immediately and may take several hours before it does
Message posted on 03 Sep 2026 08:50 PM
Hi
yes the apps are slowly coming back on the mini box.
however there are no usernames or associated passwords with these apps.
i will wait 24hrs
many thanks
Message posted on 03 Sep 2026 09:02 PM - last edited: 03 Sep 2026 09:03 PM
@Webbydog wrote:Hi
i will wait 24hrs
many thanks
Do you mean that you can't put in the user name and password into the app or they are not logined in. If it is the latter you have to log again to the app on the mini box they will not be loged in just because they are on you main box
Message posted on 03 Sep 2026 09:22 PM
Hi
yes they are not logged in with username & password on the sky mini.
i will log in on the mini using the same username & passwords for each app ( the same as they are on the main sky box.
many thanks for your help
Message posted on 03 Sep 2026 09:29 PM
@Webbydog wrote:Hi
That's correct.
