Discussion topic: How do I stop skyQ box keep turning off whilst viewing?
Message posted on 05 Dec 2023 08:53 PM
After about 45mins use the sky Q box seems to freeze. The tv screen goes blank and the box shows the blue q spinning . It seems to be resetting. After 2 to 3 mins the light goes from green to amber and I need to restart the box. This keeps happening after watching on the Apple TV app. Any ideas what the problem is please?
Message posted on 05 Dec 2023 09:44 PM
Re: How do I stop skyQ box keep turning off whilst viewing?
Hi @Bilbos
