Discussion topic: How do I connect my sky q box..?
This message was authored by: Scott247
My sky q box won't connect..how do I reconnect it..?
Re: How do I connect my sky q box..?
hi @Scott247
If it's the main Q box
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
