Discussion topic: Home Screen saying not connected to internet
This message was authored by: Emily65
Home Screen displaying not connected to internet. Have switched box on and off at the wall and tried to reconnect to network following the steps on sky.com but not resolved. The WiFi is on as other devices are working fine
Re: Home Screen saying not connected to internet
Hi @Emily65
Avatar for Emily65
Hello @oldfella
Brilliant, that's sorted it!
Thanks so much 😃
