Discussion topic: Hi
This message was authored by: Simon19731
Hi
Hi
I have had Sky Q fir about 4 years.
I currently pay £137 a month, thst includes sky sports, sky cinema and TNT Sports
I'm looking to get a 3rd Mini box so my daughter has sky in her room.
To do this online it says I have to change package to sky signature.
Doing this reduces my bill by £4 a month.
Does this mean I lose sky sports, Cinema and TNT sports with sky signature? Having to add them to my package again obviously increasing my bill by a fair bit.
Thanks in advance
Simon
Re: Hi
@Simon19731 wrote:
Hi
Thanks in advance
Simon
We're just (generally) customers on here, if you're out of minimum term then you'd need to call them and try and negotiate a better deal.
Re: Hi
@Simon19731 wrote:
Hi
Thanks in advance
Simon
hi @Simon19731
You probably will retain all your existing options but I think it can be difficult to tell.
I switched to Signature a few years ago and saved a few pounds per month by doing so
The detail is likely to be listed but can take some digging  - IIRC some screens and details do no not list anything that has not changed.
If you call you can double check and ask questions & get them to confirm everything.
BTW I presume you know of the limitations of a maximum of 2 minis in use at the same time for SKY content (only 1 with a 1TB non UHD box)
P.S. Switching to Signature is likely to  start a new 18 month minumum contract
