Discussion topic: Hi I am getting no signal on my sky q box regardless of the weather
This message was authored by Amber39 This message was authored by: Amber39
Hello my sky is not working. There is no signal ever. I think the dish is not positioned properly
This message was authored by Daniel0210 This message was authored by: Daniel0210
Re: Hi I am getting no signal on my sky q box regardless of the weather
@Amber39
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If a message displays “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
▪️I AM NOT A SKY EMPLOYEE (undercover or otherwise) ▪️
❄️Merry Christmas and a Happy New Year❄️
