1
This discussion topic has been answered Discussion topic: Help
This message was authored by: TraceyCaskey
Help
I constantly have to switch my sky q box off and on at the mains to get it to work with the remote, any ideas
Re: Help
Hi @TraceyCaskey
To re pair the remote,  With the Q box on with green led press and hold 7 & 9 together on the remote until it’s led flashes four times.
Re: Help
Hi @TraceyCaskey
