Discussion topic: Help sky q
This message was authored by: Chrisreill
Message posted on 12 May 2026 05:29 PM
Help sky q
Every so often my sky q flicks to black screen while.i am watching something doesn't matter what channel I am watching..cant speak to a human when I ring sky so annoying 🙄
Find out more
Message posted on 12 May 2026 07:15 PM - last edited: 12 May 2026 07:18 PM
Re: Help sky q
There are some simple checks/tests you can do yourself:
- Double check the HDMI is firmly seated in the back of the Sky Q box and TV
- Change the HDMI cable if you have a spare one available
- Unplug the box from the mains for a good 5 - 10 minutes
If all else fails, you can sign in and work through the online help flow here should be able to organise an engineer at the end if nothing works.
sky Q 2 TB | sky Q Mini | sky Mobile | EE Full Works FTTC | LG B6 OLED | SONOS Beam 2
