Discussion topic: Help!! PLEASE
This message was authored by: Lynette17
Help!! PLEASE
I have sky Q on multiroom the mini box in my bedroom is not doing anything!! It keeps saying to go into settings but it wont let me do anything. Please help
Re: Help!! PLEASE
hi @Lynette17
Is this a message about Accessibility ?
If so,  this message seems to have caused a bit of a quirk so try this:
Press & hold 4 & 6 on the remote to set to Infrared only (so must have line of sight of the box)
Hopefully you can then dismiss the message
Then try re-pairing in bluetooth mode with the box by pressing & holding 1 & 3 together
If this does not work try a full remote reset by pressing & holdng 7 & 9 until the red led above the SKY logo button flashes 4 times
Then try the 1&3 to re-pair & pair with the TV
