Discussion topic: Having problems with pausing, rewinding and technical fault. Recording only partially working
Message posted on 03 May 2024 07:34 PM
Technical fault - Having problems with pausing, rewinding and technical fault. Recording only partially working
Message posted on 03 May 2024 07:43 PM
Re: Having problems with pausing, rewinding and technical fault. Recording only partially working
Hi @Maxine66
See if a reboot helps.
If you still get Technical fault issues
Work through the following link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
