3
This discussion topic has been answered Discussion topic: Having issues with a small sky q box
This message was authored by: Monishine
Anyone that can help? I tried everything on the help forum and is not working. This is frustrating.
Re: Having issues with a small sky q box
Hi @Monishine
Unfortunately you haven't specified what your issues are so that makes it impossible to help.
If it is a connectivity issue with the Q mini box try the following.
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
@Monishine
What problem are you having with your mini box? What have you tried already?
Hi @Monishine
Avatar for Monishine
Thanks mate, I did all the above except resetting the main small sky q box which is where all the additional boxes are connected and that did the trick. It happened Twice today, which is super annoying.
