Discussion topic: Hard wire Router
This message was authored by: idYAHOO
Hard wire Router
Hi
I have just got Fibre to the house and i want to wire  the router direct to the tv i have the wire in place but unsure if it should go into Qbox or TV?
Re: Hard wire Router
@idYAHOO wrote:
Hi
Hi @idYAHOO
If you are predominantly using your Q box for Sky TV then you need to connect the Ethernet to your Q box.
Edit
If you have a Smart TV and want to use it for Apps then you can also connect this to Ethernet by using a simple unmanaged Ethernet switch behind your Q box.
You can then connect both your TV and Q box.
@idYAHOO wrote:
Hi
The TV is separate to the SKY Box and the TV may need an internet connection for any apps etc as well as the SKY Q box
It depends on whether either or both struggle with a wifi connection
Personally I have both my SKY Q box & TV connected via ethernet - but to do similar  you may need a separate unmanaged switch (i have one by my TV & SKY Box  which I also have my AV amp connected)
As @nigea99 indicates, both would be preferable.
Avatar for idYAHOO
Thank you
