Discussion topic: HDMI extender over Cat6 issue
Message posted on 19 Apr 2023 10:35 PM
Hi everyone, I have my sky q box setup in a comms rack in my house where I have ran cat6 cables to the 3 tv points in my house.
I have a HDMI over Cat 6 Extender (StarTech), but the picture & audio drop out every 5 seconds or so. This is not a cabling issue as I've had all the cat 6 cables tested. The issue seems to be exclusively to the sky Q box as I can stream other HDMI outputs from the same location no problem.
Any help/ideas would be greatly appreciated.
Message posted on 19 Apr 2023 10:45 PM
Re: HDMI extender over Cat6 issue
What video resolution is the Q box outputting?
Message posted on 19 Apr 2023 11:02 PM
It's set to 1080p. But lowering it to 576p only helps slightly.
Message posted on 20 Apr 2023 07:56 AM - last edited: 20 Apr 2023 08:35 AM
@NeddyFlandersWhat is the exact model, there seem to be lots, not all have the correct HDCP
This is the main Q box as the mini boxes do not support 4K.
Message posted on 20 Apr 2023 12:27 PM
Hi @bob1234
The HDMI By STartech- HDMI Over Cat5e/6 Extender - 4k 30Hz - 130ft(40m)
https://www.startech.com/en-ie/audio-video-products/extend-hdmi-4k40c6p1
The Sky Q Box is Model : ES340A-d8-UKIE
SKY Part Code 16930
Message posted on 20 Apr 2023 01:21 PM - last edited: 20 Apr 2023 01:22 PM
Q requires HDCP 2.2 (the extender only supports 1.4).
Also bear in mind that 4K signals are 2160p/50 (or 2160p/60).
Message posted on 20 Apr 2023 01:31 PM
@NeddyFlandersI believe the Q box output is 50Hz which could be the problem.
Message posted on 20 Apr 2023 02:15 PM
Hi there, I have also had a sky q box recently installed, replacing a sky + had box. This ran over hdmi and cat 5/6 extenders perfectly but now drops audio and the video jitters every now and then.
I have two tvs with the extender splitting the hdmi. HDMI not running over cat5/6 works fine.
Interested to to know more about HDC and hertz issues. Sky engineer arrives tomorrow but suspect he will say it is the cat 5/6 cable.
Message posted on 20 Apr 2023 02:26 PM
Hi @PandJ2020
Thanks for getting back to me.
Could I ask if you could recomment an extender that I could use in this situation?
Kindest Regards
Message posted on 20 Apr 2023 03:17 PM
@StuartMuirhead67 wrote:Interested to to know more about HDC and hertz issues. Sky engineer arrives tomorrow but suspect he will say it is the cat 5/6 cable.
The extender needs to be capable of carrying the Q signal - both in terms of resolution and refresh rate (which is generally 50Hz).
Message posted on 20 Apr 2023 03:18 PM
@NeddyFlanders wrote:Hi @PandJ2020
Sorry, you'll need to check the specs an ensure they carry HDCP2.2 and up to 2160p/60.
Message posted on 20 Apr 2023 05:24 PM
@StuartMuirhead67 wrote:Hi there, I have also had a sky q box recently installed, replacing a sky + had box. This ran over hdmi and cat 5/6 extenders perfectly but now drops audio and the video jitters every now and then.
Splitters also give problems depending on the type and where they are, everything connected to splitter must be highspeed and HDCP2.2.
