Discussion topic: HDMI Switcher
This message was authored by: Brynsta
HDMI Switcher
So I have too many HDMI connections for my TV (5 HDMI connections and only 4 ports) so I purchased a HDMI switcher for my SkyQ box and my Firestick, but the Sky box flashes on the display then off. It's a powered switcher by UGreen 4K 120hz HDR one, any reasons why it isn't working?
Re: HDMI Switcher
Hi @Brynsta   Perhaps it is not HDCP compliant. What is the exact model of the switch?
Avatar for Brynsta
Re: HDMI Switcher
It is a UGreen 3 in 1 HMDI Switch. https://uk.ugreen.com/products/ugreen-4k-120hz-hdmi-2-1-switch-3-in-1-out?currency=GBP&variant=46598... That's the link, checked the booklet and says it is HDMI compliant and also suggest that a problem could be the device I'm using isn't HDCP compliant, which the sky q box is
Re: HDMI Switcher
Hi @Brynsta   It looks like it should work, what happens if the Sky Q box is the only input. Note HDCP compliant means your TV, not the Sky Q box which requires the switch to be HDCP compliant. Not the other way round.
Avatar for Brynsta
Re: HDMI Switcher
I tried that, works for a slightly longer spell, maybe 5 seconds, the. The screen went grey and then black, then the no signal input again. TV is an LG G4 so shouldn't have any issues with HDCP
Re: HDMI Switcher
How long are the cables?
Avatar for Brynsta
Re: HDMI Switcher
Standard sky one from the box to the switcher, same again from the switcher to the TV, even tried swapping the switcher to the TV one to a brand new UGreen 0.5 hdmi cable, same result
Re: HDMI Switcher
Well, in theory, it should work.
A long shot could be the switcher is 'faulty'.
I would note that the specs do not list the 50Hz used by the Sky box.  But I suspect this is red herring as signals are just passed through - I doubt there's any 'processing' done.
Avatar for Brynsta
Re: HDMI Switcher
That's what I'm wondering, I will try and get a new one from them and see if that fixes it. Hoping it will, not sure what to do otherwise!
Re: HDMI Switcher
Is it externally powered? We've seen issues before with switches relying on the Sky Q box's HDMI port for power.
Re: HDMI Switcher
Specs say it's powered and needs 1A.
Avatar for Brynsta
Re: HDMI Switcher
Yup, plugged into a wall USB plug
