Discussion topic: Gill
This message was authored by: Travelgirl43
Gill
My sky mini box in bedroom keeps losing signal
Re: Gill
Hi @Travelgirl43
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box.
Failing all this and you still have issues you may need a Sky Q WiFi booster positioned midway between your mini and the main Q box.
Sky will provided these free to aid Sky Q connectivity.
