Discussion topic: From startup - blue light remains glowing
This message was authored by: ozsat
So at 5.45am the main box comes up with the blue glowing Q light.
At 6.10am the blue light is still glowing yet the box is running fine.
Any ideas why this would occur?
SkyQ Silver bundle (V2 2TB with UHD/HDR + two minis) in Sky region #71 (Oxford) using VirginMedia Gig1 Fibre (1.2Gbps/100Mbps).
This message was authored by: Danz994
Re: From startup - blue light remains glowing
Posted by a Sky employee
Hi @ozsat If the box is running fine, this could be to do with Eco settings on your box: https://www.sky.com/help/articles/using-the-standby-settings If you need further assistance with this, please let us know and we can send you an invite to chat. Thanks, Danielle
Avatar for ozsat
Level 12 icon
It is set to Eco and has been for several years.
Never seen this issue before - but the box as switched itself on (and the tv) 2-3 times over the years.  The wakereason then was that somebody has pressed the panel button.
I'll let you know if it does it again.
This message was authored by: lainys
Good Morning @ozsat ,
I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Thank you ^Lainy
This message was authored by: twilight+princess
It could be updating the firmware which depending on broadband speed can take some time. If it's happening every morning then I would try manually updating, if the problem still remains & turn off the box & unplug from the power socket & wait a few minutes then plug back in again.
Virginia.
I don’t work for Sky.
If I have helped then please leave a like.
Avatar for ozsat
Level 12 icon
It is nothing to do with the firmware updating. The light did not returned after a reboot - except when it should.
@ozsat OK.
Virginia.
