Discussion topic: Freezing
This message was authored by: kwat909
Freezing
Sky keeps dropping out -tv freezes
If I go onto settings it sometimes says network connection as a cross - sometimes it is a tick but still freezing
Re: Freezing
Hi @kwat909
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
