Discussion topic: Freezing sky q box
This message was authored by: Pauljg383838
Freezing sky q box
My sky q box keeps skipping parts of the shows whilst watching on recorded programmes,
it also won't fast forward straight away then doesn't stop once I've pressed the play button.
Re: Freezing sky q box
@Pauljg383838
See if this helps…
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
