Discussion topic: Freezes on standby
This message was authored by: nmilner7
Freezes on standby
Sky Q box keeps freezing. There is a green light on the box but no signal to the TV.
The remote is working fine and works again once I turn the mains plug off and back on. This has been ongoing now for a couple of months and now needs sorting as I shouldn't need to continue to hard reset the main box which then impacts my two mini boxes.
Regards,
Nathan
Re: Freezes on standby
@nmilner7 wrote:
... and now needs sorting as I shouldn't need to continue to hard reset the main box
So you're aware this is a customer-led help forum - you are not contacting Sky customer services.
If you want a box swap you'll have to contact them.  Remember to remove your viewing card if a swap is arranged (and check power supply as some boxes have a brick to supply power).  You will lose all recordings.
Alternatively, there are some reset procedures to try first if you wish?
