2
This discussion topic has been answered Discussion topic: Fogot 4 digit code to sign in
This message was authored by: Gary20245
I've forgotten my 4 number sign in code how do I reset?
This message was authored by: nigea99 Answer
Re: Fogot 4 digit code to sign in
hi @Gary20245
It is usually set to the last 4 digits of your Viewing card unless you have changed it - see:
Home - Settings - System Info
If you do need to reset go to :
Home -  Help - Reset PIN
& follow the instructions
hi @Gary20245
Avatar for Gary20245
Level 0 icon
Hi great worked straight away thank you
