Discussion topic: Faulty sky q mini box
Message posted on 17 May 2024 08:29 PM
My sky q mini box is stuck with a red light and won't turn on. I've tried rebooting it twice. How do I get a replacement box?
Message posted on 17 May 2024 08:35 PM
Re: Faulty sky q mini box
Hi @Oliver15
Have you tried pressing the Standby button (Amber led) on the front of the min box.
If this turns the mini box on
With the mini box on with green led try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
