Discussion topic: Faulty Sky-Q box
Message posted on 12 Nov 2024 09:16 AM
Faulty Sky-Q box
I have tried all the rebooting and trouble shooting and the Q-Box won't show any sky programmes, the green light is on the remote work the signal strength good and sat signal yet no picture .
Message posted on 12 Nov 2024 09:39 AM
Re: Faulty Sky-Q box
Any error messages displayed on the screen?
Message posted on 12 Nov 2024 12:06 PM
No just reads player 3 sky-q and that's all been 3 weeks now as I'm unable to speak directly to anyone.
Message posted on 12 Nov 2024 12:09 PM
Hi @WAYNEYC33
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box.
Not an error message I've heard of. Any games being played on the TV?
Message posted on 12 Nov 2024 12:11 PM
Thank you oldfella , 👍
Message posted on 12 Nov 2024 12:13 PM
No games i don't play them I'm 59 just wanna watch the usual programs
Message posted on 12 Nov 2024 12:20 PM - last edited: 12 Nov 2024 12:39 PM
This thread suggests that's a message generated by a Sony television, and may relate to lack of resolution support.
'Player' appears to be default labelling on rather elderly Sony menus for any external HDMI device.
@WAYNEYC33 What model is the television set?
Message posted on 12 Nov 2024 12:23 PM
If I recall that error message you mention is related to a Sony TV or similar TV hdmi error message, when it can't handle the current Sky box selected resolution.
On your Sky remote, press Home, 1080, Home so you can access the Sky Q menus and choose a resolution that works.
https://www.sky.com/help/articles/changing-the-screen-resolution-setting
Message posted on 12 Nov 2024 01:55 PM
Sony Bravia KDL-40,EX503
Message posted on 12 Nov 2024 01:58 PM - last edited: 12 Nov 2024 02:03 PM
OK: that's a 15 year old model which has a maximum resolution of 1080p ('Full HD') so it's not going to display anything if the Q box is outputting UHD.
Message posted on 12 Nov 2024 02:01 PM
Strange as it has worked up until 3/4 weeks ago!
Message posted on 12 Nov 2024 02:05 PM - last edited: 12 Nov 2024 02:12 PM
The most likely explanation is the Q box was previously set to output a resolution which the rather elderly television can handle, but has had a software update or a reset which changed this.
Try the key presses which @lettice described above.
