Discussion topic: Faulty Sky Q box
This message was authored by: Symondb
Faulty Sky Q box
My box keeps dropping out snd has to be rebooted to get the picture. This also happens if you scroll channels. The picture is fine
This message was authored by: Doc5907
Re: Faulty Sky Q box
@Symondb
Try a Reset Settings in the hidden menu.
Scroll down to Reset
After the Reset you may have to re pair your Bluetooth remote If you use one.
Sky Q 1TB UHD
LG TV
Sky Mobile
